7mgte diffrence between loom colors
Neal
83
Melbourne
Guys,
Im in the process of buying second hand loom for my mkiii, which is in so much better condition than my current loom.
My issue is that the loom im buying has yellew ECU plugs as oppose to mine which are grey. Is there any diffrences between them apart from thier colour.
Thanx
crazysupra2JZ
740
Georgia
the yellow plugs are for pre89 supras while the grey ones are for 89+
i'm not too sure they will fit into your ecu. i think the 89+ has more pins.
92nsx
2,957
Clearwater, MN
^^^^dido, ECU will be differn't form yellow to gray need to buy the correct year ecu, pre89 and 89+ are differnt. But the clips under the hood should be the same gray will fit into yellow and viisa-versa sp? if that is even a word. I happen to like the gray better a little easer on the eyes.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Some under hood will fit...some will not fit too ;)
I really wouldn't base the decision on how good the plug color "looks".
Personally, I would stick with the year harness in the car.
