12/1/2006
Got my CPS rewired 2 days ago. The shop soldered another used connector with good wires (from a pic-a-part) to the outside wires of the CPS. They shrink wrapped the connections, put some 1/4" flexible conduit around it and taped over that. Shop charged $30. While I might have done it myself, the soldering demo that I saw was a great lesson. It has been decades since I have held a soldering iron.
I only learned afterward that the rubber baffle into the CPS might be dispensed with so the wires could have gone into the inside of the CPS. Didn't find out what would substitute for the rubber baffle to protect the CPS interior. Anyone know or have ideas?
See below for the local Vegas prices from 3 dealers on these special order parts. Interesting how each dealer is choosing a different pricing M.O. Got lucky because if the LA warehouse has it and you order before 930am, it can come in the next am. Found out that the numbers I show below taken from the EPC pix are just pix id #'s not the actual part numbers. The online EPC I used will connect to the full part#.
#1 #2 #3
19127 CPS cover gasket 2.63 3.13 3.16
19107a O-Ring 2.11 2.51 2.54
19121 Cover 5.12 6.09 6.16
19155 Gear and Pin 53.67 63.87 61.64
19155 said to be not available in the US The others were special order to L.V. from L.A.
I spent another $1 on a piece of hose from the thermo housing to the turbo. Put everything back together with no trouble, fired it right up and set the timing. Everything looked fine.
Tip: I set the crank to the #1 compression TDC per the TSRM BEFORE I pulled the CPS so I was just able to plug it back in to the same position and the timing was virtually the same as I had left it.
So far, so good.
#1 #2 #3
So far, so good.
