7MGE swap won't start NEED HELP!
JayTRD
Elmont, NY
I have a '91 7M swap that I'm doing and after finally getting everything where it needs to be I can't get it to start. The new motor that I have in it now is JDM spec so there were some minor things switched over (intake, injector plugs, dizzy) and now it won't start. I'm getting fuel, spark and combustion but thats where it ends.
donnie N.
8
Olympia,WA
Make sure the maf sensor is good.Test everything that way you know everything is in working order and make sure the idle speed controller is working.You will know its working when you turn the key off and hear the clicking from the drivers side of the engine.Also time everything again pull the dizzy and try putting it a hair before number one firing point.If this doesnt work check fuel pump again and pressure to the fuel rail.
