7m first start up and dyno vids :)
mytmk3
643
christchurch
well after far too long the time finaly came and it runs :)
first start up :)
[video=youtube;7kciYmvAycU]http://www.youtube.com/watch?v=7kciYmvAycU[/video]
first stage of dyno tuning 280rwkw at 12.5psi
[video=youtube;tiJ7P6UkJrY]http://www.youtube.com/watch?v=tiJ7P6UkJrY[/video]
car goes back on the dyno on monday try to get another 100kw :) will get a better vid with something other than my Iphone if I have time to go down and see it
mytmk3
643
christchurch
mk3tattoos
sounds good! and looks good!!! put up some vids of it on the street
carter;1630720 said:
I second that one
cheers guys will do ashamed to say still havent even driven the car yet! thay cant seem to get the dash to work and now the NZ drift comp starts this weekend they are flat out getting all those cars ready so mines parked for atleast another week then still have to get it certified warrented then rego and its prob gunna fail cert because im not legaly alowed to be lower than 100mm at any poin of the car including exhaust and my brake lines are fome the us so they prob wont alow them and not alowed to be over 90db for the exhaust and if they think its too powerfull I have to get drive shaft hoops put in... to many dam rules :)
probly not going to see a road vis for a month id say not looking forward to hacking up my expensive ss exhaust just so its not too low
kikdurazz
what's the birdcage for?
winnipeg
Man that sounds so healthy. What is your setup?
Just did the conversion for us North American folk 496 rwhp well done sir.:bowdown:
mytmk3
643
christchurch
thanks mate set up is:
Remote oil cooler
Sard fpr
single walbro (reason didnt get more power)
custom sump
eagle rods
je pistons
ARP- flywheel bolts, rod bolts, main and head studs.
cometic 2mm MHG
fully balanced bottom end
mild head polishing (not overly note worthy just a small clean)
comp cams valve springs
toda cams 264/272
titan cam gears
ebay ss exhaust mani
masterpower t70 .68 ar
tial 44mm wastagte and 50mm bov
3" downpipe with wastgate plumbed back to 3.5" cat back
2.5" hotside 3"TB I/C pipes with 600x300x90 I/C
KS racing FFIM with Q45tB
52mm alloy radiator with 2 12"fans
Delphi 680cc injectors
Link G4 storm ecu with display dash
w58 box with spec stage 5 clutch (removing that and putting in r154 and os giken triple plate this weekend
many more mods just not power related :)
