7M Engine Harness Connectors
Enraged
A HG job took HOW long??
21
Victoria, BC, Canada
Just thought I would post this up for reference. Attached are PDF catalogs of Sumitomo connectors.
DrTweak sells many: http://www.phoenixtuning.com/zenstore/index.php?main_page=index&cPath=867_868
Another company with good service is EasternBeaver: http://www.easternbeaver.com/Main/Elec__Products/Connectors/Sealed/SM-MT/sm-mt.html
Both vendors respond quickly, so if you have questions on whats what, contact them.
Also, this place has conversion harness for injectors if you don't want to splice your harness: http://www.lsxtune.com/shop/index.php/cPath/109_175
  • p_sl_e.pdf
  • h_hw_e.pdf
  • b_mt_e.pdf
  • d_ts_e.pdf
  • f_hm_e.pdf
Enraged
21
Found that thread after I posted, we should just get my post tacked onto that one for reference.
And I still can't find the connector that plugs into the coils...
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
I can get you the toyota part number for that...but I'm not sure what the sumitomo part no. is.
terminals are the standard 090 MT series
Enraged
21
ya, the problem is the sumitomo part number. I've got some extra terminals, so I'll probably just depin the connectors on the harness I have and rebuild it (using IS300 coils, stock harness isn't long enough).
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
yeah, my advice is to do it that way.
I extended mine using the toyota pre-crimped wire leads (before discovering a source for the sumitomo terminals) and ended up spending nearly $50 more than I had to. (I think the pre-crimped leads were ~$20 each!)
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
Thats because not everybody knows that the terminals are easily available for cheap...had I not come across the easternbeaver site, $1/terminal woudl have seemed like a good deal compared to what toyota wants for a pre-crimped terminal/leadwire
