7in Tablet in place of the head unit
Doat
2,599
Houston, TX
I was thinking about installing a 7in tablet to replace the head unit, have it plugged in like route the power cable behind the dash to the cigarette lighter so I can possibly charge things with a car charger at the same time as charging the tablet or will that be overloading the cig lighter? Anyway, I need some help on figuring out a mounting system that is as clean as possible and holds the tablet very sturdily. I want to use it as my GPS, radio, MP3 player, movie player, etc. I will also have a cable run out through the glove box or something so I can add things to it like transfer movies and songs through a usb drive or something like that. The tablet I have in mind is the Galaxy Tab T849, I am more worried about the mounting rather than the wiring because worst case I just run the cable from behind the dash and stick out into the car charger if I can't wire it up to the wires directly. Also would it be possible to have it turn on with the ignition instead of having to manually turn it on and off?
Backlash2032
1,823
Nebraska
Somebodies been watching MCM.. :p
For the speakers: You will need an external amp. Run the 3.5mm to the high level input i believe... Don't quote me on that.
For USB: I can think of one way which would work great. Run a USB cable from the tablet into the glove box, and have a female USB cable in the glove box ran to your car charger/cigarette lighter wiring (should work fine, even with other things plugged into the front. Or you could use the 12v stereo power and ground as you won't need that anymore) So you can disconnect the tablet from the second USB cable and plug it into your computer for instance to transfer data. Once you're finished transferring, plug it back into the power USB cable and you're done.
And honestly with the turn on/off thing, all you'd really need is it to sleep. A tablet is going to take far too long to power on to be very useful on short car rides. I'm not sure on the settings, but you should be able to have the screen turn off when not charging, and when charging the screen would never turn off. On my HTC Rezound I can set it up to do exactly that. But it isn't running factory ice cream sandwich..
For mounting: I'd go the MCM route and use some epoxy and some metal strips. Or something along those lines.
Doat
2,599
Houston, TX
While I have been starting to watch Mighty Car Mods I did not get the idea from them lol I had the idea for awhile since apparently a 7in screen fits well in our cars and thought why not put in a tablet to have everything I want and also design the UI myself or customize it at least. I did not know that MCM did this I will definitely hunt for that episode when I get off of work. I want the tablet to sit cleanly and flush with the head unit area. So the only way to get input to the speakers is to run the external amp, I can't use the stock setup like an adapter or something?
Backlash2032
1,823
Nebraska
http://www.youtube.com/watch?v=u-ALYArl5S4 There's the MCM video.
The stock headunit has no aux. input so no. And the output from the tablet will not be enough to power the speakers. It was mean't for headphones. Even some headphones have a tiny amp in them. So you need SOME sort of amp. Be it either an aftermarket amp, or an aftermarket headunit stuffed away in the glove box or under the seat or something.
Just rewatched the MCM video. I'm not sure if its necessary to add a potentiometer to the amp input, as they were using the ipad dock for audio, not a 3.5mm headphone jack.
Doat
2,599
Houston, TX
What kind of amp would I need like a 500W amp or something? I have not dealt with car audio stuff in so long the last time I handled that stuff was in my brother's 96 impala SS helping him install his sound system and we did that in early 2000s
Backlash2032
1,823
Nebraska
Depends on what speakers are in the car. You need to match the amp to the load rating and impedence rating of the speakers. Chances are you will need a 4 channel amp, unless you have a 6 speaker setup in your car. In which case you'd need a 6 channel amp.. I however, have not had any luck finding one of these.
Really though, you're only going to have a left and a right coming from the tablet, so it would be kind of pointless to get a 6 channel amp.
Doat
2,599
Houston, TX
I only really want to hear the speakers in the cabin anyway I don't care about the speakers in the trunk, my spare tire and jumper cables don't need to rock out with me lol I believe my mk3 has 6 speakers it's a 91 turbo targa if that makes a difference. I need to replace my speakers anyway the stock speakers have no balls lol. After I replace my clutch and fix my AFM issue I will look into speakers and setting this all up but right now I just want to plan everything out and make sure it's do-able without crazy modifications I wish I knew how to do some fabrication work I would just make my own brackets that fit into the stock bracket or whatever. OH my main concern is the heat from behind the head unit area because I know how hot the radio and the in dash pocket gets so I was wondering if you guys know a way to block heat from behind the area like maybe make a wall of foil or something.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
I do like this qoute
Poor mans version.
step 1. obtain Ipad
step. 2. buy mp3 cassette converter.
step 3. connect ipad to cassette to cassette player.
step 4. super glue, duck tape, or nail ipad to car dash.
step 5. enjoy.
Doat
2,599
Houston, TX
lol I am just looking for ideas at the moment I don't want to glue it to the dash but when I came home I held the tablet over my head unit and I can see it fitting beautifully with a few little modifications to the dash itself like trimming up the trim piece a little bit from behind to let the tablet sit flush AND since our dash isn't plastic it's more of a leather type material it can actually help hold the tablet in place.
Doat
2,599
Houston, TX
Thanks, I've been checking that site out and it has been helpful but I need some supra specific help with like making mounting brackets and such.
Backlash2032
1,823
Nebraska
Honestly just use some thin metal strips and glue them in. Or use some duct tape.
Sent from my terrible HTC Rezound using Tapatalk. Don't buy HTC...
Doat
2,599
Houston, TX
lol I don't want to ruin the tablet I was thinking of shaping some metal brackets that would bolt to the stock radio cage/brackets
gurley0916
Gurley=Last Name not girl
Mar 10, 2008
1,138
Columbus,OH
Your going to have to get real creative. I plan to hard mount it in the dash, then have the bezel sit in front because the bezel is so hard to get on with my short throw shifter.
Doat
2,599
Houston, TX
I actually want another dash so I practice my cut outs with that and test fit everything but it's hard to find MK3s in junkyards in my area.
Backlash2032
1,823
Nebraska
I never said to screw anything into the tablet. I still stand by that it would be far easier to just glue metal brackets to the stock radio surround or just duct tape the tablet to the surround.. It's not that hard to do this guys..
Doat
2,599
Houston, TX
Not saying it's hard I just don't like that route because it won't do what I exactly want lol. Tape will get loose over time and since the area behind the radio gets pretty warm the adhesive will get gooey on long drives and tapping on the screen along with bumps in the road and gooey tape won't end well lol. I was thinking of having 2 brackets that bolt into the factory radio bracket to hold the tablet from behind and put some sort of soft or padding around the edge of the dash on the front side of the tablet, so it holds it snug.
Backlash2032
1,823
Nebraska
Unless you fasten the tablet to the bracket somehow then its going to be a giant pain to get in. And you'd be surprised at how well gorilla tape holds up in situations like that...
Doat
2,599
Houston, TX
Once I have time to open up my dash and take a look at everything I am sure I can draw up some ideas to make a bracket that holds the tablet securely. My main concern is figuring out how to block the heat from that area.
I just realized I have a double din dash kit, I shall check that out to see if I can play with it that way I can use the stock radio brackets to mount the dash kit and attach the tablet to the kit itself or something.
mecevans
1,295
M-bay, cali
Nexus 7 has pogo pins on the side for charging and audio. Would make it much easier to make a removable dock.
