Yes, 6M dampener is unique to the setup. The timing gear setup is a bit odd as well, you either machine a 5M lower timing gear shorter, or use a 7M lower timing gear, 7M oil pump gear (also need to use the shaft to clear the rods), and a 7M belt.
The real issue is the accessories and lining them up. 7M pulley bolts on, but getting everything to line up is the issue. Tanya's car runs only the water pump and alt, PS and A/C were deleted. There is a way to run the PS off of the water pump pulley, but you still lose A/C. The alt belt is thinner than it should be, and will sometimes slip. It's annoying, but 6M pulleys are extremely rare.
Supposedly you can have the 5M pulley bored out and broached to fit the 7M crank, but I think it might be easier to get a custom pulley made from ATI. Fair bit safer too.
