I'm doing a manual swap with my Cressida and I wanted to k now if the bell housing from a 5M would bolt right up to the 7M. And the clutch/flywheel/pressure plate. Could I use the ones from a 5M as well?
m series is all of the same, as for the bellhousing bolts.
a 7m bolts right in there, you can re-use the stock flywheel on the 5/7m although i would sugest getting atleast a new stock mkiii n/a clutch the pressure plate is rated for a heavier car, more clamp pressure.
and i think the though out fork is the same.
5m6m7m mgte starters are the same. although some say the 7m n/a starter is the highest torqe out put.. ?
I'm not sure if any of you would know, but would the drive shaft from a MA70 work in a Cressida (MX83)? I know the drive shaft I have (automatic) won't work for me.
