51 and 52 error codes how do I fix this problems?
ashiharausa
suprazone
51 show ac switch I can leave wout aircondition if thats what it means? No idl signals nsw,tps been replace,ecu?
52 knock sensor been replace anything else should be replace?if you had encounter this my car is like doesnt want to do full speed ahead?
Thanks
T3rril79
246
Huntsville Alabama
MkIII FTW
401
Huntsville
T3rril79;1953808 said:
Here is a thread on 51; http://www.supramania.com/forums/showthread.php?46793-Code-51 . Be sure the your tps is calibrated properly (http://www.mkiiisupra.net/joomla/index.php?option=com_content&task=view&id=38&Itemid=29).
Finally if you replaced the knock sensor and you are still getting 52 (the code will make your car run like crap), that is usually an indication that the wiring is bad and need to be redone. There is a nice write-up on here as to how to accomplish that.
You would definitely be the one to know ;)
ashiharausa
suprazone
Thanks how many knock sensor does 7 mge have? And which color of wire should I hook it up on ecu to positive knock sensor single wire? T.y.
