4.8L Turbo build
msimsi10
169
Novi, MI
So, after being sick and tired of messing around with the I6 motors I decided to get a GM 4.8L V8. It's a LR4 out of a 2003 truck. Quite a few people are pulling big numbers on these motors and running the 1/4 mile in the 9's. We'll see how this goes.
Picking it up. Getting it in here wasn't easy at all lol
placing it in for fitment. I just shimmed the motor where I wanted it and started making mounts. I got a mock up trans from summit it was so much easier when using an real one and not to mention cheaper.
Trans it weighs about 10lbs
mounts
me welding away
Started to mess around with the manifolds and found out the head was cracked. Good thing I got the motor locally and there was a warranty on it! They were originally just going to replace the head till I pulled it off and found sludge in it. It pitted the cylinder walls and at that point I just got a new motor from them.
New motor lets try this again
It fits pretty well
Steering column clears with no problem
I think the turbo is going to end up sitting here I'm probably getting a BW S472 of S475
most likely putting the radiator fan in the front to gain some extra room in the bay too.
msimsi10
169
Novi, MI
Riceman83;1888924 said:
Glad to have another ls build. Looks like yours is a lil further than mine.
Do you have a thread going for yours yet? I haven't really done much the only took a weekend let me know if you need any help with the mounts.
MightyAl
293
Chesterfield, MO
I just got my mounts done and I made drawings. I am thinking about putting a few sets together. I used the stock isolators. Did you solid mount your engine?
Here is a link to a guy local to me that has a build thread on LS1tech. He has a 4.8L turbo setup in a probe. Right now he is just trying to put the power to the ground.
http://ls1tech.com/forums/conversions-hybrids/1373962-ford-probe-turbo-4-8l.html
msimsi10
169
Novi, MI
That looks good. I'm just am not sure what accessories to run on the motor what kind of alternator mount did your buddy use?
Notsafe1jz
Ohio
Are you staying FI or throwing a carb on that thing?
LSX motors(and their sister engines) are the shit. They pretty much give you 400 to 500 whp for free with the right set up.
msimsi10
169
Novi, MI
Staying FI probably a Borg Warner S475
MightyAl
293
Chesterfield, MO
He built a custom mount because all he is running is an alt. No power steering or A/C.
Suprapowaz!(2)
2,870
San Antonio, Tx.
This is what I'm going to do if this 7m decides to give out on me. 4.8, or the 5.3 is good for me. Good luck on build, post lots of pipcs and tutorials, and vids when running. Thanks.
Riceman83
Eat rice it funds my mk3
Sep 9, 2012
88
Arkansas
Yes it's under red lead sled lol
Chambers
Now you know
Sep 9, 2007
981
Baltimore County, Maryland
I saw a magazine article using that engine I think, they put a eBay turbo on it and made 400 some horsepower, and only spent like $2500 for everything. After I saw that I knew it was a engine to consider, glad to see someone thinking outside the box. What kind of room do you have for a downpipe?
