3 gauge pod issues
dragracer
GearHead
Oct 31, 2005
221
Churubusco
I have a Lotek 3 gauge pillar pod. Bought it several yrs ago. Sat with other stockpile of parts.
Figured Id throw it on to add an extea gauge over my 2 pod.
Well:...............the lowest gauge pod hits the dash to the point you cannot even get the thing in place. Kinda bumbed about this.
Anyone ever have this problem? I know a bunch of these are out there.
Figured Id see if there was issues before I call them. Though I doubt they will do anyything given the time.
SupraMario
I think it was the google
The Farm
I dont wanna sound like an ass but you did remove the stock a pillar stuff right? And yes I have a lotec 3 pillar and it needed a tad bit of shaving done to it but it fit in there like a glove. Pictures might help us more.
dragracer
GearHead
Oct 31, 2005
221
Churubusco
Yes, i removed old. And dash is bolted in.
The lowest pod sticks out a little more than the top two. Dont think I can shave it to fit. A bunch would have to come off.
steven89
892
Houston, TX
My Lotek 2 gauge pod needed quite a bit trimmed off to fit it. Its really easy to see how much needs to be shaved off when you set it right next to your stock one. But like i said, I had to trim a LOT off of mine.
MKIIISupraGuy
639
Lousy-ana
I have a Lotek 2 - gauge, and it went right in with no trimming. You do have to take a little care to make sure you insert the end nearest the dash first, but once I had that in the rest was cake.
te72
Classifieds Moderator
6,603
WHYoming
Perhaps they've been modified from Lotek over the years to fit better? I believe all I needed to do to mine was run the Dremel through the pods themselves to get the gauges to fit inside.
dragracer
GearHead
Oct 31, 2005
221
Churubusco
My 2 gauge Lotek fits fine. When you look at my three pod the lowest one sticks out a little more that the other two. Wouldnt be a problem if it was the top two. But the bottom one is right up against the dash. My buddy has one and all three stick out about the same. I might have just got a bad one. I will try trimming and see what happens.
