Well at work today I decided to compare the differences between the 2.
I looked at the stock pistons for each motor.
Everything was the same, (dimension wise) bore size, Pin size, Ring height... Everything but the skirt length. But when I checked it with a CP 2j Piston... The skirt length was the same as the 1j. I double checked all the measurements with our Engine Builder at SP and he concurred that indeed they will work. We are going to toss a set into a motor and make sure all is good.
I will be sure to report back with any and all info I find out.
Tim@SP
Tim@SP
