It has 3.5 inch exhaust I don't think thats the issue.
whit a 3.5 i dont think it is the issue either ,change the spring,the 7psi spring you have is good for 14psi you all manage to squeeze 4 more psi out of it change it for a 14 psi or if you can get 16 psi is good and you will notice it.
i hurt two engines on the street after tunning on the dyno because we dit not know,the boost was doing the same thing the dyno here you cant load it,because of thad you will try to raise the boost and it wont go up and as soon as you hit the streets it will go to the last boost you set it up,lets say the last time you try to raise the boost on the dynoit came to 20 and dit not want to go more up you will try again to raise lets say to 22 and it will only go to 20 you will hit the streets whit the car and it migth even go to 24 psi and so you will hurt your engine,what i do i will lower the boost to 18 psi and i will raise it on the streets to 20 psi.
