Hoping someone that has performed this swap can tell me if I have the correct parts, or where I am going wrong-
I have a 92 supra to swap the 2jzgte - vvti into
BIC 89+ brackets
What I think are MK4 engine mounts
I did search and have verified the correct mounting location for the brackets.
Problem is on the exhaust side ( see pics)
The BIC mount hits on the turbo support arm
The engine mount hits on the stud that holds the support arm in place
the turbo lines do not line up at all
Do I have the correct engine mounts?
Do I need to grind down the support arm to make clearance?
Oil hoses? Do I have the correct piece on the oil pan? the turbo lines?
Befor I start hacking things up, want to make sure.
I did search, and did not find others that had these problems, or good pictures to reference
Any help would be greatly appreciated, I am stuck
Thanks
Steve
BIC 89+ brackets
Thanks
Steve
