2jzgte JDM swap
tcd300
13
baton rouge
Aright this is what i'm working with some fourm i read it say it would work some say it would not.
-jdm motor
-jdm harness "will extend" - would it work with the usdm ecu? I was told if i get the usdm ecu my injectors wont work right.
-jdm ecu - i was told this was not interchangeable with the usdm ecu - so that means i need a stand alone? like aem ems or map ecu?
-i was told the jdm motor is a little bit weaker then the usdm by 40hp so like you said i can change out the Jspec to usdm like
-injectors
-cams
-turbo
can i still keep my jdm ecu? or i have to change it to a usdm or stand alone?
I just want it to be at 320 where it needs to be.
i'm not sure if i asked this question yet but do you know if the jdm waterpump is interchangeable with the 2jzge motor?
I was thinking to upgrade the injectors only and then maybe i can up the boost? I read on something and it said i need a resistor or a clip? I'm not really smart with these stuff lol
Thanks,
Ton
