just built a 2jzge with a 2.4mm MHG and i want to use a hx35 because it has similar characteristics as the ct26 as 57 trim. and the holset is big down here in the south with all the diesels. anyways im curious how a hx35 does on a 2jzge and will it produce enough to get 500hp on a 8.5:1 CR while using pumpgas. my max will be 500hp but daily tune will be 400hp. any tips on maximizing the use of the hx35? without the use of nitrous.
