2jzge in 87 turbo $$$$
Orangeracer
SUPRA LOVER
Sep 12, 2008
82
Harford County, MD
So i have a 7mgte currently with rod nock. I found today a guy with a 130k 2jzge out of a 95 supra it comes with motor trans ecu harness and all exaries. He is asking 500. He pulled it out of the car today. to replace it with a tt 6spd. So do you guys think i should buy this and turbo it. or rebuild my 7m it seems like the 2j would be a better deal. Would i be able to sell it for 500 if i get it and change my mind?
cvc9216
11
MD
I need that 2JZGE if you don't buy it! I'm in MD too. Honestly if you want to turbo the 2J you might be better off buying a GTE motor since you're looking for a deal.
Wills7MGTE
( . )( . )'s RULE!!!!
May 12, 2006
1,077
Jackson, MO
Check out JMCBOOST's NA-T swap thread in this section.
He has a 1990 7MGTE supra with an R154 he swapped for a 2JZGE and NA-T it, got a 70mm turbo, ffim, fmic, and standalone for under 6500 total cost of swap so far, its almost running got some hoses and stuff to finish up but it will turn over.
