2JZ Solstice Build
pantherqs
25
Windsor
So I decided to shove a 2JZ in my Solstice. The Solstice transmission [aisin ar5] bolts right up to the JZ with the JZ bellhousing. Will post a more details after I figure out a few more things.
Build so far:
2JZGE
Borg Warner S372 1.0 AR
Precision 1000cc's
AEM EMS v2
LS Coils
Custom fabbed intake manifold/dp/everything
Mishimoto rad/IC
Spec Stage 5 pressure plate/Custom Spec Stage 5 clutch disk
Some ARP/Supertech/HKS toys
Motor:
Old motor comming out:
2JZ going in:
pantherqs
25
Windsor
Recap of tonight with non-shit pics.
did this
swapped these
rear sump clears the crossmember so well
then attached stuff
so big
then i did this
then did a tranny
then used a forklift to put that...
...in here
like this
then tom ground some stuff
... stood up here and pointed at stuff
and then the 2jz was in
and the peasents rejoice
gone well..
te72
Classifieds Moderator
6,604
WHYoming
2543arvin;1723420 said:
Looks really nice!! How much do the Solstices weigh?
A lot less than most Supras, that's for sure.
I approve of this project 100%. How much of the engine did GM in their infinite wisdom ( :: facepalm :: ) stick under the cowl? Always hated that about newer cars...
pantherqs
25
Windsor
Update: Everything major bolted up, torqued down, and dropped in. Transmission transmission's. Driveshaft driveshaft's. Clutch clutches. Mount's mount. Thing's thing.
titan sent some stuff
bumper got mounted
tom mocked up the intake manifold...
...then welded a series of tubes together
and hi 4 inch downpipe
None of this would have been possible without the masterful fabrication of Tom at Ontario Mandrel.
te72
6,604
WHYoming
You're gonna have to get a couple videos of this thing when you're driving it around... Definitely gonna raise a few eyebrows with this under the hood.
