So Im posting on behalf of a guy I know at work doing a 2JZ swap into his lexus..
He had his head machined, cleaned the block surface, and got a new stock 2j head gasket. Used a light coat of copper spray and torqued it all down. Then realized he forgot to put the dowel pins back in.
I told him it IS necessary to have those in place, but he is now wondering if he can simply just pull off the head again (i mentioned it is important to loosen them in proper sequence), install the dowel pins, drop the head back on and torque up the arp studs without machining the head again. (the engine hasnt even been run yet)
He hasnt had much luck finding an answer as of yet, any suggestions I can pass on?
Thanks
Thanks
