2JZ-GTE VVT-i Top Feed Fuel Rail
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
Looking to buy a top feed rail for the 2j vvti,but all I see on ebay are ones that day. Not for use with vvti or Will not for vvti head models...is this just a myth? Or does it work with very little modification? Any help appreciated. Thanks.
toyotanos
What will we break today?
2,841
Coon Rapids, MN
I grabbed a non-vvti one and it works just fine. Mind you, you'll have to get the intake manifold injector adapters for whatever size injectors (11mm/14mm) you have. Admittedly, I am using a USDM upper intake and throttle body, so there may be a difference if you're staying all OEM.
WonIt
Air ,Fuel ,Spark!
Feb 26, 2006
175
Front Royal,VA
yea,i was thinking the rail should work. if not there would be someone making them specifically. thanks for the response. time to order one.
