Well, here's the 2JZ-GE head on the 1JZ-GTE block. I figured I had the two pieces why not make a motor with it? The 1JZ head is going on the GE block. We used ARP head Studs, and the bottom end is stock. My more recent post on Page 2 talks about the issue we're having finishing this. You can see the water recirc port on the exhaust side of the head. I want to plug it up, others think that would be a bad idea.... Anyway....
The manifold is an Ebay one in the pic, I'm using a Boostlogic 2JGE manifold and Tial WG. 74mm Comp TBB w/ ETT, .84 housing(custom turbo).
Injectors: 880cc, Magnafuel 625 external.
The Stinger went in the other car. This car's getting a Haltec Ek6. This motor will power my 83 Supra L-type, Jawsgear True-Track and one piece steel driveshaft through a R-154 Transmission. ACT pressure plate, feramic six puck.
I don't even know what this swap is called. Basically, it's another JZ engine so I said why not.
What do ya'll think?
