2jz Engine bay. Anything wrong here?
chopstickz
227
SoCal
Hi, I was just wondering if theres anything wrong in these pictures? Thanks (Mainly BOV and other hoses/lines)
synco357
32
Fort. Lauderdale
Blow off valve will be protecting the primary turbo from surging. However, the secondary turbo doesn`t have anything protecting it. Secondary turbo need a BOV in its` charge pipe. Failing that just place the valve before the throttle body!
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
i actually think that is where it T's off so both should be ok, and all bov's are going to be before the throttle body its just how close that counts
lagged
1991 1JZ
new rochelle
wow theres some wacked out responses in this thread.
other than the fact that its a kludge and there are cleaner ways to install an aftermarket BOV, that engine bay looks fine and should run fine.
if you dont like the way it looks either put the stock BOV back on, or get some hard pipes to replace the stockers.
