So the other day my car would not start come to fine out the harness that goes by the egr pipe got melted and got code 14. I thought it was cps at first so i swapped the wires out with a different one on the same housing. I did not know what the air gap is or cant find it so that may be the problem. Also on the harness I rewired one of the knock sensor wires that was burnt. I did not shield that part I cut away to get to the signal wire could the brake up be that or maybe my solder job on that wire was bad? If i throttle pass 2500 I drives fine and will boost great. Also has a lope idle. I'm going to try and find more about the cps air gap tomorrow. Also at the time my wideband was reading passed 18 and would only get my numbers once I hit boost witch was 11.1 wot.
