I have no idea whats going on right now, I'm making the thread kind of short since I still have some daylight out I don't want to spend too much time typing this up until later.
Basically it all started about a week ago, I drive the car home perfectly fine and park it for the night, the next morning I go to start it and it doesn't want to start, it just cranks and cranks and eventually stops... what stopped it was the cylinder filling up with fuel. So we pull all the plugs later that night and spin the motor real quick to get the fuel out... we see that injector 5 is stuck open. So at this point I figure my injectors got messed up so we pull the injectors out to get them cleaned and flow tested and rebuilt if need be. Long story short I get scammed by the local fuel injection place so I end up buying a set of 550's off my friends MKIV which are in known working condition. I finally get around to putting them back on today, drain the oil for a long long long time to make sure everything is clean inside, put in 6 quarts of amsoil 10w30 and crank it with the EFI fuse pulled to make sure I have good oil everywhere.
I go put the EFI fuse back in and go to start the car, it sounds a bit funny and I was really not confident with the car at that point so I pull the plugs and everything out and take a look inside. Cylinders 2,3,5, and 6 are all full of fuel. I have no what is going on, I have a stock ECU and a Mines ECU and both of them seem to make the car do the same thing.
Any help is appreciated.
