Hi, I'm having a little problem getting my 1jz started. I loaded base map on ecu and it fired up, it was running extremly rich but running. The next day I tried to start it up and it would only crank not fire up. I've got no spark and plugs were dry.I've check fuses and wiring. I'm new to EMS Stinger v4. I could really use some advice on what would cause it to suddenly stop working. I've got fuel pressure,12volts at injectors,ECU, And I'm going to test fire injectors as soon as I close this thread.Any advise would be helpful I'm at wits end with this problem!!!!! THANKS FOR READING!!! HELP
