Hey guys,
I know this sounds retarded, but i am wanting to find some solid answers here with evidence to back it up.
In light of 1JZ stock headgaskets becoming extremely limited in quantity and increasingly hard to find. I am wanting to investigate the use of the stock toyota 2JZGTE headgasket on a 1JZGTE block and head. Now i have testimonals from a few people that have used such a hg on a 1.5JZ with no ill effects or issues at all. The concern is the water jacket holes are moved around and the oil passages are smaller. Thus this could affect cooling and lubrication to the different 1JZ head. However if there was cause for catastrophic concern, we would have heard something about heads warping/exploding and BHG's.
I am not wanting to debate which headgasket is better i am simply wanting to know if i can run the 2JZ hg without issues on my 1JZ with rebuilt head.
2JZGTE headgasket is thicker, however this is normally not an issue because one would have had their head milled and block possibly as well to make up for the small difference.
Link to thread with pics of both HG's: http://www.supramania.com/forums/showthread.php?47831-Difference-1jz-and-2jz-headgasket-*pics*
I have a 2JZGTE hg and can drop the head on ths weekend but if its just a bad idea all around then i will order up one of the last 1JZGTE hg kits and use the hg from that. Perhaps we could have a role call of anybody that has done this, using the 2JZ hg on a 1JZ.
Thanks guys for your help and advice.
