1jzgte pistons
Cya
628
Columbia, S.C>
I'm looking into replacing my pistons since I have a good feeling that my rings are shot. I know about the hastings 3sgte rings and the cp pistons, im wondering what else is out there so that I can weight my options.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
try JE'S and weisco, i'm not sure if they have 1jz pistons but they should have 2jz pistons
fandffan
149
Bowling Green, OH
This has been covered...
But.
2j rings will not work on a 1jz. The hastings is an actual 1j rings set.
2jzgTE pistons will drop right in but you have to use 2j rings and it will work fine.(generally new pistons come with them). Do not get the 2jzge pistons as they are high compression pistons.
Sam
251
Saskatchewan
But.
Do you mean 1J?
