After the swap i started the motor it started right up with no problem.
Yesterday i finally got the coolant, PS and Hydro setup so i can have the motor running.
The motor was running for about 5 to 10 minutes and it just shut off. i try to stared it back but it wont start.
The motor is getting gas
I have power to the coils and ignitor and the ecu also have power.
I'm getting code 21 which is O2 sensor (connector came busted up) which im sure would not affect my problem right now.
I did research and found that it could be cam, crank senser, ecu, ignitor.
Can Anyone help me figure out what it could be? or how to figure out what is wrong?
Thanks in Advance
Thanks in Advance
