1jz valve cover gasket PN, and valve clearance?
mkiiichip
1,434
WI
i am in need of valve cover gaskets for a 1jz. Id like the toyota part number. thanks.
What are the valve clearances supposed to be?
Also i ordered two o-rings, for the oil filter housing, for a 95tt. not sure if they are going to fit. anyone else try these?
Dirgle
Conjurer of Boost
Pauma Valley, CA
While I do not know if the 2JZ gasket will or will not work. The part numbers are different.
2JZ-GTE: 11214-46011
1JZ-GTE: 11213-88400
