1jz twins problem
chuckmuska2005
265
canton
Just finished my 1jz swap and found that the rear turbo has oil in the charge pipe to the intercooler. so I got a bad leak, questioin is do I replace both seals or just swap out for new twins. the turbos on there now have no other problem.:1zhelp:
ModularTurbo
MasterPower Rep
May 4, 2008
128
Homestead, FL
www.modularturbo.com
Depending on whether or not you plan on increasing power in the future you might as well upgrade to a single or go the cheapest route and replace the seals. I wouldn't replace the stock turbos for stock turbos unless you never plan on turning up the power.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
It is not a matter of IF your stock twins will blow, it is WHEN your turbos will blow. Just go ahead and get a nice single, so much more worth it in the end for not too much money (IIRC, it will be about 3k-3.5k for mine including parts and installation).
