Water temp Sensor checks out so i checked voltages of every pin on the ECU connector with the ignition set on run and the battery attached to another car,
X represents no wires coming that pin
1JZ_ECU_Pin_Outs_Supra_MK3_JZA70_Complete02 by
kareem.richards, on Flickr
X Plug
1- Oxy Sensor Heater- X
2- S From Neutral Start sw - X
3- L from Neutral Start sw - X
4- ISC 4 - 13.18 V
5- ISC 3 - 13.18 V
6- ISC 2 - 13.18 V
7- ISC 1 - 13.18 V
8- S3 A/T - X
9- S2 A/T & CRUISE - X
10- S1 A/T - X
11- #20 - INJECTORS 3,5 - 13.18 V
12- #10 INJECTORS 1,4 - 13.18 V
13- EARTH, MANIFOLD - 7.8 mV
14- FC TO CIRCUIT OPEN RELAY - X
15- VF DIAG - X
16- FUEL PUMP RELAY - 13.19 V
17- IGF RPM1 - 8.54 V
18- IGT6 - 6.18 V
19- IGT5 - 6.19 V
20- IGT4 - 6.18 V
21- IGT3 - 5.93 V
22- IGT2 - 5.91 V
23- IGT1- RPM2 - 5.93 V
24- E1 GROUND - 16.6 mV
25- #30 INJECTORS 2,6 -13.20 V
26- E02 - EARTH MANIFOLD - 7.6 mV
W PLUG
1- VC VAC SENOR - X
2- PIM VAC SENSOR - .466 V
3- THA AIR TEMP -3.01 V (CONNECTOR LEFT UNPLUGGED)
4- THW WATER TEMP - 2.125 V
5- OX SENSOR - X
6- KNOCK SENSOR 1 - 17.5 mV
7- TE1 CHECK CONNECTOR - X
8- TT CHECK CONNECTOR - X
9- EARTH FOR 1,2,3,4 - 10.1 mV
11- IDLE AIR CONTROL - INCONCLUSIVE (COULDNT GET A RELIABLE READING)
12 -X
13- X
14- KNOCK SENSOR 2 - 18.1 mV
15- TE2 CHECK CONNECTOR - X
16 - X
DIDN'T BOTHER GETTING VOLTAGES FOR U PLUG SINCE I HAD THE PREVIOUSLY
T PLUG
1- BT SWITCHED POWER VIA EFI RELAY - 12.56 V
2- EFI FUSE - 11.92 V
3- M-REL SWITCHED GROUND THROUGH EFI RELAY 11.83 V
4- M CHECK LIGHT - 8.3 mV
5- ELS TAIL LIGHT INPUT - X
6- A/C CLUTCH SWITCH - 12.44 V
7- A/C CONTROL SWITCH - 11.08 V
8- SPEED SENSOR -4.73 V
9- OD2 FROM OD SWITCH - X
10- XXX
11- NEUTRAL START SWITCH FOR A/T - X
12- +B SWITCHED POWER FROM EFI MAIN RELAY - 12.62 V
13- IGNITION SWITCH ST2 -12.61 V
14- STOP SIGNAL - X
15- L3 TEMS - X
16- L2 TEMS - X
17- L1 TEMS - X
18- ECT FROM CRUISE PIN 7 - X
19- M A/T MANUAL SWITCH -X
20- P A/T AUTOMATIC SWITCH - X
21 - XXX
22- NSW SWITCH 12V FROM ST1 12.53 V
