1jz injector question
ma70mkiii
139
ohio
So I had to pull my injectors out and they smelled like varnish. None the less the rubber o rings at the very bottom tip where the injectors go into the rail at the intake manifold. My question is are the 2jzgte o rings work on the 1jz injectors. I need to know so that I can order them and get it going.
Dirgle
Conjurer of Boost
Pauma Valley, CA
According to Toyota they are the same part number between 1jz and 2jz.
Fuel Rail Intake Lower seal(No.1) - 90301-14006
Fuel Rail Intake Upper seal(No.2) - 90301-17007
Insulator, Injector Vibration(No.1) - 23291-75010 - there are 2 of these one at the top of the injector and one at the bottom
Insulator, Injector Vibration(No.2) - 23291-76010 - this one goes where the fuel rail meets the head.
Hope that helps
ma70mkiii
139
ohio
I was jus making sure because I test fitted ones off of a 7m but I know that the 1j and 2j are damn near identical so I figured the 2j stuff would work I just wanted to make sure. Thanks for the help.
