1jz head 2jz-GE bottom+Ge gasket?
nick88
JayHall's Hero
May 10, 2009
794
Des Moines, Iowa, United States
There will be no valve clearance, but there will be compression problems. The ge is 10:1, I think but am not sure, someone correct me if I am wrong. And I have no idea what the tt gasket puts compression at.
rakkasan
Currahee!!
Fort Campbell, KY
with my 1.5, I went with a 2.0mm MHG. My calculations before I assembled MY MOTOR gave me a 8.8:1 C/R. A recent compression test yielded 174-180psi. Motors vary, so check your data and run your calculations to determine what YOUR compression will be.
Blow up your motor by using my info and I will laugh at you. Very hard.
