1JZ-GTE A/C Idle-Up
Jeff Lange
Administrator
4,918
4
Calgary, Canada
jefflange.ca
Just looking to know what the functionality is supposed to be like on the 1JZ-GTE A/C idle-up, the car idles up fine, but it seems like it might be idling up too much. Typical idle speed is about 650rpm on the car, and when the compressor cycles it will jump up to about 1500rpm, and then sometimes settle down near about 1200rpm. It seems excessive to me, haha.
Jeff
^your a/c compressor is not wired up correctly. the signal for the compressor relay needs to go through the ecu so it knows the a/c compressor as been turned on.
That seems high but i would not complain as it would never stop blowing cold lol. sometimes it starts blowing hotter air with lower rpms.
cyrusthegreat
11
Blythe, California
Thanks for the reply HvyMan. So it sounds like I should follow the wiring from the compressor and check to see if it goes to the compressor relay then follow the wiring from the relay to the ECU? Is this how you would go about it?
