Hi guys, trying to figure out why my car is not firing correctly. Recently took the car apart and rewired it, mostly just shortening wires and removing unused circuits like abs, diag, ac, etc. Put the car back together and it turned on but ran horribly, like its only firing on a few cylinders. All the plugs were covered in so its getting fuel and all the spark plugs seemed to be firing. Got a code 14 so we checked the ecu IGF pin and it was only outputting 2v instead of 5v. It didnt matter if the IGF wire was hooked up or disconnected, still 2v at the ecu. Any ideas why the ecu is only outputting 2v at the IGF? I recently had it send to driftmotion for their recap service and it came back and it worked fine. Now after we took my car apart and put it back together, it is misfiring.
Is the ecu even supposed to output 5v on the IGF pin or is it the igniter that outputs 5v? Also, checked the TPS, MAP, IAT and Coolant temp sensors with the key on. TPS and MAP had 4.95v and the other two only had 2.6v. Should all of these be running off of the same 5v system in the ecu? Should they all have 5v with key on? I am just a little confused on how the 1jz ecu works.
Any ideas?
Any ideas?
