1JZ Ebay exhaust... Do i need anything else ?
Royalmaas
22
Norway
Already have a Profec B, FCD and Wideband installed + some minor mods, so i think it should be ok. Have been running a 2.5" with a 7M before and just recently got the 1J swap done.
f00g00
586
Kuwait
The second pic is a replacement Y pipe and down pipe. The Y pipe will probably be a pain to change.
Royalmaas
22
Norway
Hmm, from what i can see from the picture i posted it looks like i might need a test pipe to make the exhaust complete..
#04
526
Cambridge
check the flanges on the y-pipe assembly, prior to install, mine needed resurfacing due to heat - warp-age
as well my downpipe bends were slightly off and ended up being too short and touched the floor, it may have been my new mounts/bushings but likely the jig was made a little sloppy....
nctexan
268
Houston
AbsoluteSpeed;2008512 said:
Test pipe seems to be built into the downpipe.
Then again, they also say it is "TUG" welded, so who know what's going on over there.
You've never seen TUG welding?! Man it's incredible!! :ugh:
