1jz cutting at 5000rpm after 1zz coil install.
cpederson
117
wi
Car is 1jz, pt6265, rc1200's, walbro 450, e85, ngk iridiums gapped at .024, 1zz coils, haltech ps2000. Now the car will pull fine sometimes but mostly it will cut/lose power at 5000rpm to 6000rpm then power with come back like someone hit the Nos button. I have no idea what it could be, I've gone thru everything, clean the injectors, new plugs, different plug gaps, messed with the tuning a lot, I just can't seem to pin point it. It also troubling bc it's not consistent. Any input would greatly help
Thanks Corey
Radial
252
Norway
sounds like you are missing sync from 5-6k to me.
Check your trigger system for errors (check for full sync on cam+crank all the way to the redline).
