1jz--2jz turbos are they the same
barry
Quebec
are the 1jz--and 2jz turbo ct12a the same size turbo.I know about the ceramic wheel wondering about the size.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Im not THAT knowledgeable with the 1j/2j turbos. Iirc it depends on I they came from japan for use in japan. I think the 2j turbos have two different sets of twins.
Again, Iirc the 1j turbos have ceramic wheels and are smaller than usdm 2j turbos
mkiiichip
1,434
WI
Correct, the 2jz can have two different sets of twins, and the 1jz had a completly different set of twins, or a single.
The largest twins are the 2jz USDM twins.
SupraMedical68
Formerly medic91x
Feb 26, 2007
376
Nashville/Clarksville
What's the material used for the USDM 2JZ turbo's compessor wheel? Some sort of steel or something? I've never really paid close attention them, but I have to say they can take quite the beating.
Albert
May 13, 2009
1,710
Tempe, AZ
Ct20 is JDM 2jzgte twins. Ceramic Turbine, Aluminum Cast compressor wheel.
Ct12b is USDM 2jzgte Twins. Steel Turbine, Aluminum Cast compressor wheel
CT20 and Ct12b are Interchangable. External are identical. Internal; the CT20 is bigger shaft and IN/EX
CT12a is JDM 1jzgte Twins. Ceramic Turbine, Aluminum Cast compressor wheel
You can put 2jz twins (CT20&CT12b) onto the 1jzgte motor with slight moddification.
All I can see that would be a problem in the rear turbos from the 2jzgte (CT20 or CT12b) arnt actually internally gated. Its gated for post Turbo, not pre. So you would have to sleeve or weld the turbine housing and drill a hole through the wastegate port into the scroll to get it to be internal gated, to run on 1jz as true parallel.
AlterEgo
Sugar Land
USDM 2jzgte ct12b: steel
JDM 2jzgte ct20a: ceramic
JDM 2jzgte VVTI ct20a: Steel (<not typo)
JDM 1jzgte ct12a: ceramic
JDM 1jzgte VVTI ct15b: ceramic
