FYI:
In case anyone is interested, I'm having some crank sensor adapters made. I'm making them for use with a 1/2" Electromotive sensor.
They're going to bolt into the stock location, retained by the original bolt and they're going to have a "pinch" mount that will allow you to set the clearance as necessary.
I'm also trying to get some 60-2 wheels done (in the factory size) so I'm going to have some lower timing belt pulleys all ready to go, so that Electromotive ECUs will be a 100% bolt on setup.
