17x10" wheels +5 offset
92gtapex
76
Northland, New Zealand
17x10" +5 offset 235/45
trial fitment
It clears!!!
even with some of the camber wound out
about 40-50mm between the inside edge of the wheel and the strut
Logan
Sawbladz
1,727
Oshawa, ON, CA
What good is a 10" wide wheel if all you can put on it is a 235? That tire would fit on the stock 7" rims. When you widen the wheel you increase your unsprung weight so the only benefit would be the capability to install larger tires. Since you can't...whats the point. Sorry...but I just don't get it.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Because it's JDM tight yo! :biglaugh: But it does look cool!
I would rather try to fit a 295 on a wheel with the correct offset :dunno:
Because I only want mad dorifto when I try, not every time I hit full throttle. LOL
tissimo
Stock is boring :(
Melbourne, FL
I'm all about aggresive offsets, but thats just rediculous.. I could even see a bit (5 maybe 10mm) more then I have
but thats just.... too much.. like a little low rider with the wire wheels that stick out of the wheel wells..
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
garagefujimoto said:
LOL I won't post my pics, for fear of having someone like Ric in my throat haha...that said, it looks awesome
Nah, just post it. BTW, I don't think you want any guy "in your throat". That's nasty (in a Cleveland voice). Haha, just jokin yo!
tissimo
Stock is boring :(
Melbourne, FL
18x10 +35 275 tires.. its 4x4ing on eibachs though.. same wheels thats in my sig (a good 1/2" or so lower then the eibachs on coilovers) my fronts stick in though, need a spacer eventually :( Very slight rub on the rear with full compress.. so gotta roll it when throw a 295 on ;)
heres another from the test fit on my 87
