wardog;1399439 said:
I talked to the person the techat Eagle Electric and he told me that it didnt matter how small or big the shell looked. It was the insides that count because all they do is re-wound them to 130 or 160 and install our voltage regulator and connector.?
That is not entirely true. Yes, they re-wind the alternator with a longer coil which produces more power, but the physical size of the housing will limit the amount of extra wire they can add. Smaller housing = smaller coil = reduced power output in comparisson to a larger housing. I've been told in the past that rewinding an alt gives at most around a 25% increase in amperage output. So if you start with a more powerful factory alternator, the output will be all that more powerful after it is rewound. These tiny alternators that we bought off ebay may have only been 65amps to begin with. The rebuilders actually pushing 130 amps out of these tiny alternators, as advertised, is simply an impossibility. Still, I'd really be interested in seeing what they do push.
Hey were did you get that smaller pulley at?
I sourced a pulley for a 81-88 Mercury and had it machined down to work.
Check out my posts in this thread for all the info:
http://www.supramania.com/forums/showthread.php?t=98079
