I have been thru the TSRM and can't seem to locate a 12 volt switched source wire that i can use for the flex-lite fan controller (mounted on the fender near to the battery and fuse block). My car is not wired hot now so I can't poke around with a test light to see what is hot when the key is on.
Really dont want to use any wires to/from the EFI circuits or ignitor ckts.
Any ideas? :nono:
What about the turbo boost sensor located on the drivers fender? I dont think i will be using this as I am going with a AEM/GM boost sensor instead. Can't seem to find it on the TSRM either - has 3 wires to it (orange, tan, white) solid no stripes on the wires.
Granted i can find 12v switched from the harness off of the ECU but dont want to run 10 feet of wire, when there is probally a source near to the battery location.
Any ideas? :nono:
