12s
IndigoMKII
2,181
Madison, Virginia
What does it take to make these cars break 12.99? I keep being told over and over that my mods will not break 12.99.
Yes, I plan on running my car at the track but it's roughly 2 hours away and I've got a few more things I want done before I even do a shake down at the track. So the question is, if I can cut a 1.8 on 255 hoosiers, will it break 12s with my mods?
customs
175
Edmonton Ab
I think thats possible forsure. Suspenion is going to be the next thing that will hold you back. What are you running for suspension?
IndigoMKII
2,181
Madison, Virginia
Stock worn out suspension. I've got a set of kyb gr2 waiting to be put on but I'm not replacing those til I get sub frame bushings and control arm bushings. I'll do it all at one shot and put in eibach springs then reset my camber.
aixgelo78
58
Cherry Hill, NJ
your car should definitely hit high 12s with 360whp and some decent traction, ironically soft rear suspension is at times preferred for drag racing.... Its all driver limited after that
Suprapowaz!(2)
2,870
San Antonio, Tx.
My car went 12.91 on Nitto 555r's with a 2.0 60ft time. I would guesstimate that I'm putting down around 315rwhp. You can definitely hit 12's with those Hoosiers and 360rwhp. Good luck and post results.
San Antonio, Tx elevation - 650ft.
Madison, Va. elevation - 604ft.
I bet you could hit low 12's with the power you're putting down.
