Hey guys,
So I finally got my fuel issue sorted out, bad connection by my connector going into the fuel tank, and thanks alot to all those who helped me trouble shoot it!! SO... My next question is...
I did the 12 V fuel mod and got all the wire hooked up and the relay all set up but I couldnt get the pump to turn on, I am not sure if it is my relay (view the posted pictures) or something else (I just tried to follow Shaeff's diagrams and how to's). So does anyone know if there is something I can try or common problems, I just hooked the Fp and B+ together to bypass the Fuel Pump Relay and Tried to link the two for the resistor (can bad connections make the new relay not work?), but the car will start when the resistor, fuel pump relay and the fuel pump wire is hooked back up to the stock b+ wire for the fuel pump.
If anyone has any ideas that would be awesome, maybe I miss interpreted the wiring diagram on my relay, maybe someone could tell me what goes where? Thanks again, you guys rock!!
