1.5j compression ratio?
Boostage
323
Florida
I dont know if anyone knows this. But Im trying to figure out the c/r of a GE block with 1jz head with stock TT HG
Boostage;1458931 said:
yeah I know clubna-t I searched there before I posted here. there is no info on what Im asking over there.
The info is on there, because I had to figure out my cr and I used the formula that was posted on that site. The thread was made by cade5150 or something like that.
rakkasan
Currahee!!
Fort Campbell, KY
When I ran the numbers a few months ago (while doing my build), it came out to 10.2ish. I used a 2.0mm HKS MHG, and I ran a compression check that yeilded 176-180psi.
Correct me if I'm wrong on the current C/R Jay.
That seems high Mark, but I wouldn't doubt your mathematical prowess. I would have thought the 2.0 would have brought it down more than that. How much boost do you think we can run on your setup with that high of a compression?
rakkasan
Currahee!!
Fort Campbell, KY
The 10.2 was with a stock GTE gasket, I should have made it more clear. My bad Jay and Boostage. I had my wife look up the numbers on my computer at home. They are: 176, 174, 173, 175, 174, 173, with a 2mm HG.
I think 18psi is safe, and as high as i want to go. Maybe tune to 19.5psi, but set the boost controller and the boost cut at 18psi (max)
Boostage
323
Florida
ok so only 1 point difference. thanks
Do you remember what your CR is Mark? It was 10.2 with the stock, do you know what it is now? Isn't yours like 9 to 1? When I did mine, it ended up being 8.67 to 1.
18 psi sounds perfect to me. I'll have race gas in it so I can tune it to about 22psi in case of a boost spike, and then we'll set the stinger boost cut to 19.5 for added safety.
