1.5 JZ with stock twins
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Hi guys/gals,
Does anyone have any information on this setup?
1.5 JZ utilizing stock twins.
I'm just curious as to how it perfomed/performs.
How the oil feed was ran?
What size oil feed is used?
I know its the logical thing to swap out for a single setup, but it would be interesting to try out the twins first.
Thanks.
tissimo
Stock is boring :(
Melbourne, FL
Wes (harwewe1 on SF) ran this setup last year in texas. He maked 400whp on the twins iirc @ 18 psi. I think he used the stock lines, just bent them to be longer..
Rich
tunin' tha beast
Jun 2, 2007
319
the netherlands
i drove around for over a year with that set-up and yes if you're carefull you can bend the oil feed and drain, that's what i did
it is an 'instant boost' set-up, really good fo daily drive, but it chokes up top though
i didn't put it on dyno
suprastanger507mgte
Hayward , Ca
yeah thanks for that first hand response. I have an option to go this setup until i get the gt4082 rebuilt . The twins I have are in great shape and should last kong enough with my driving style. Also, i will be using a 2JZge block so the oil feeds will not work on the block as is. I will have to make custom oil feed line tapped into one of the bungs on the 2JZGE oil housing and split into two for the twins.
Anyone know what size oil line I should run.??
Thanks,
