1.2mm or 2mm head gasket?
holdbrooks
114
Alaslama
I just read the head shaving thread and searched around a bit, but was wondering what you guys thought about it all.
I just picked up my motor from the machine shop and they took about 0.014 off of the the head and block combined. I know that stock is 1.37mm and to keep stock compression I would need a 1.73mm hg. so my question is should I undersize or oversize the thickness of the hg? The Block has also been bored 40 over and using reconditioned rods (slightly shorter I presume).
I would thing a slightly higher comp ratio would be better on a n/a than a lower one what are your thoughts?
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
holdbrooks;1077917 said:
this one is going in the 89 na the 88 is still great.
Gotcha. Like Jay said, Cometics come in any size you want, and like Greg said, compression is better, but I don't know that you'd really see any significant performance difference.
supramang
74
Farmington
i dont exactly remember what size gasket i used or anything but i know i went with a little higher compression and it made a worthy difference in performance id go compression style:)
