Thinking About Shaving Moldings on My MK3 Supra – Any Tips for a New Owner?
johnmicheal02
Shaving the moldings on your MK3 Supra can give it a cleaner, more streamlined look, but it’s a modification that requires careful planning and execution. Here are some tips for a new owner:
  1. Preparation is Key: Start by thoroughly researching the process. Shaving moldings involves removing the factory trim and filling the mounting holes left behind. You'll need to decide whether you’ll do it yourself or hire a professional body shop.
  2. Bodywork Skills: If you’re doing it yourself, be prepared for some bodywork. You’ll need to weld or fill the holes, sand the area smooth, and apply primer and paint. Precision is essential to avoid uneven surfaces or paint mismatches.
  3. Choose the Right Materials: Use quality body filler, primer, and paint to ensure durability and a factory-like finish. Investing in professional-grade products will make a noticeable difference in the final result.
  4. Consider Resale Value: Shaving moldings is a permanent modification that may affect the car’s resale value. Some purists prefer keeping the MK3 Supra as close to stock as possible, so consider this before proceeding.
  5. Professional Assistance: If you’re unsure of your skills, it’s best to consult a reputable body shop experienced with Supras or similar projects. This ensures a flawless finish and saves time.
  6. Blend the Look: Shaved moldings work best when paired with other subtle aesthetic upgrades like a clean paint job, upgraded wheels, and lowered suspension to maintain balance in the design.
Shaving moldings can significantly enhance your MK3 Supra's appearance, but take your time to plan the project to ensure a high-quality outcome.
