Switching 1jz to sequential injection
Bluemax189
21
Md
Looking into converting my 1jz to sequential injection over this winter season. Using AEM V2 and looking to upgrade turbo and injectors. Currently have an awesome running car on 550's and gt35.
What is the injector phasing I need to set for the sequential injector vs my current batch? anything else I need to change besides running the new wiring?
Usually it’s wiring in the firing order. 153624.
So for the v2 you need to look up the 2jz pinout and verify which wires it wants where.
Bluemax189
21
Md
not worried about the physical wiring. that's easy enough, its the software side changes I have reservations about
ok then you need to go into the coil/inj tab and set what injector pins your using. with batch there would only be 3. sequential you would need to check the boxes for the other 3 and make sure you have the injectors wired to the correct pins.
