So last night I decided to beat on my 2jz mk3 with the stock twins at a local strip. I did 3 back to back hard runs( balls to the walls kind of driving) and I noticed on my last run that I was running warm. When I say warm, I mean that the temp needle was at 3/4 the way up(not into the red and not boiling over) as I was coasting in after my last run. I let it idle for a minute then the temps were back to normal. I have a newer stock mk3 na radiator and the stock clutch fan set up. I was thinking that I might be running a little lean and it was causing it to warm up, I dont have a wideband installed so I cant really know for sure. Maybe its just because I dont have enough air flow through the rad? Ill check for blockages last today. any ideas? The Waterpump, rad cap, radiator, and coolant are about 12-18 months old too. Any ideas on what could be causing me to run warmer after multiple hard runs?
